Bogarts offset
Old Dec 26, 2003 | 10:32 AM
Dragaholic's Avatar
9 Second Club NA
Default Bogarts offset
I was just wondering if I have the right offset or not. I didnt bother to specify which offset that I wanted, but I did bring it up and Steve said that he had it covered. To be honest, I really dont even know what offset is. I have a basic idea, but nothing complex. Anyhow, my wheels look great, however, the back didnt seem really deep even though its a 10" wide rim because the center section was pushed out so far to the front. Is there any reason why they are made like that? Do they have to be built with that offset for everything to work without any modifications? I just thought that with a 10" wide rim, that it would be a bit deeper to give it that mean look. Do all of you that have a set have the same offset for the rears? I have a pair of 26x11.5x15s that I'll be mounting on them. Thanks in advance.
Old Dec 26, 2003 | 10:49 AM
White Fire'99's Avatar
Originally Posted by NVMySS
Do they have to be built with that offset for everything to work without any modifications? .
thats it right there, but i'm sure steve will give you a better answer
Old Dec 26, 2003 | 03:16 PM
SJM Manufacturing Inc's Avatar
They are set at ~7.5 BS. It should state this on your packing slip attached on your box. I have them ALL set this way unless the customer specifies otherwise. If we went in any further, you would have to perform some serious modifications to your inner fender area.
Steve
Old Dec 26, 2003 | 03:20 PM
You can view some of them located at www.sjmmanufacturing.homestead.com
