tire psi
Old Mar 1, 2010 | 05:57 PM
Charles Holmes's Avatar
Default tire psi
At is a good tire psi to run at the track with m/t drag radial.
Old Mar 1, 2010 | 07:52 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
It's a trial and error type thing and also depends on how the track is hooking
Old Mar 1, 2010 | 09:22 PM
VTC_WS6's Avatar
Really depends on the level of track prep, but I usually find myself hooking best at about 18psi. Strart high and work down, but keep your launches consistant.
Old Mar 2, 2010 | 12:07 AM
69z-28's Avatar
like said, consistency is important, and will be the biggest factor, especially if you have an m6. start at around 24 PSI and work down to 16 or so. I found my Nittos worked best at the track at 18 psi. stay consistent and trial and error is your best bet like said. good luck
