wider tires in the back better handling? Are wider tires on the back beneficial to handling? or just give the car more understeer? |
better traction |
plus they look better |
I'd say it depends on your power level. if you have a higher HP car- I am sure even 315's would still oversteer. I find my car is pretty well balenced with 315 M/T drag radials...I can still get her loose when putting the power down on exits. |
Originally Posted by FrankSS
(Post 13195922)
better traction
Originally Posted by SHovV
(Post 13195975)
Originally Posted by Leedogg
(Post 13196771)
I'd say it depends on your power level. if you have a higher HP car- I am sure even 315's would still oversteer. I find my car is pretty well balenced with 315 M/T drag radials...I can still get her loose when putting the power down on exits. I Strongly Agree with all of the above!! LOL |
handling just depends on the car, mine has 315's with 4:10 gears and it will get crazy around corners depending on what gear im in or how much throttle i give it. |
the car has konis, stranos, 35/22 sway bars and at the moment 18x9.5s all around with nitto NT05s |
sounds like you have it set up. If you find it pushed the nose now- more rear grip will aggrevate that condition further. |
I am also interested I will post a thread in the handling section |
© 2024 MH Sub I, LLC dba Internet Brands
