What size rims for my application? help
Old Jan 7, 2004 | 11:30 AM
770Guy's Avatar
Default What size rims for my application? help
Big bore
4.30 gears
I wanna go with the Weld Pro Star series rims, but dont know what size slick to run and what width rim with what offset. any info would be great.
15x10 rear? 15x3.5 front? 29inch tall slick?
Old Jan 7, 2004 | 06:30 PM
770Guy's Avatar
TTT need to order these, any help would be appreciated.
Old Jan 8, 2004 | 04:19 PM
SJM Manufacturing Inc's Avatar
Your going to need some spacers with the rims some grinding. I believe the spacers are about .3125 inches.
You would want to choose ~7.5@10inch for the rear and ~1.75@3.5 inch for the fronts. I wouldn't choose a smaller rim as your tire widths are more limited.
A suggestion is to choose a set of Bogarts which are lighter, higher quality and built FOR your car. To give you an idea, choosing a set of bogarts and comparing unsprung weight/static weight issues vs choosing a set of welds you would be saving ~80 lbs with the Bogarts...the Bogarts have their advantages and are literally worth their weight in $$. They just don't look pretty
Give me a call or e-mail if you need additional assistance.
Hope this helps,
Steve
