prostars
Old May 19, 2010 | 10:04 PM
txhemi840's Avatar
Default prostars
im buying some for my 99ss and heard that i might need extended wheel studs cause the stock ones might break going down the track from being short...is this true or no
Old May 20, 2010 | 08:48 AM
wheelczar's Avatar
The length of the stud has very little to do with it breaking. What you need to look for is thread engagement. You need enough lug nut thread contact as possible to maintain the proper torque requirements to keep the wheel tight. The Prostar uses a 1.3 inch long shank lug nut and extends into the wheel to reach the stud. How many turns will you get on your lugs when you put them on?
Old May 20, 2010 | 09:34 PM
txhemi840's Avatar
not to sure yet ill be buying them tommorow
Old May 21, 2010 | 08:18 AM
kierstyn's Avatar
You will need longer studs for the fronts if you run spacers. The rears should be fine. Also on the fronts you can run the Arp 2.5s but if you want the extra assurance they have the 3.25s. On mine I run the 2.5s in the front with a spacer and closed in lugs. On the rear I have the 3.25s with open end lugs.
Old May 22, 2010 | 03:57 PM
SURPRYZ's Avatar
Good choice!
Old May 24, 2010 | 09:47 AM
rod214's Avatar
Default Prostars
This helped me when I installed Prostars on my 2000 Pontiac Trans Am .
http://www.freewebs.com/casper9t9/dragwheelinfo.htm
