What do you think of these wheels?
Old Jun 1, 2010 | 11:04 PM
smokinponcho73's Avatar
Default What do you think of these wheels?
The wheels are summit fast five's. They look like weld wheels but will they work?I need something that is somewhat affordable and I will be able to put a 28" slick on. I dont want to grind a ton off of my calipers but don't mind doing a little bit to make it work.
http://www.summitracing.com/parts/SU...66PS/?rtype=10
Thanks Brandon
Old Jun 2, 2010 | 02:44 AM
Mr.z/28's Avatar
A few guys on here are actually running them.
They pop in here soon.
Old Jun 2, 2010 | 02:58 AM
Mike Broadway's Avatar
They will look fine !!
Old Jun 2, 2010 | 03:38 AM
flippincamaro's Avatar
Yup, They will work great, I have the same ones on the front of my camaro, Waiting on my rearend swap to be finished before I order my rears. Just get the 4.75 lug pattern.
Old Jun 3, 2010 | 08:24 PM
craig h's Avatar
summit fast five wheels 15 x 8 w/5.5 bs , 15 x 4 , tires are 165/80/15 federals &
255/60/15 firestone firehawks. i did very very little grinding on the calipers,probably a minute or 2 per caliper. no spacers.
Old Jun 3, 2010 | 08:47 PM
Camaro396's Avatar
They look great for a knock off of Weld products. Of course they weigh about 10lbs heavier, but if you're going for "the look" you can't beat the China wheels.
Old Jun 3, 2010 | 10:58 PM
Im going for cheap 15"s that fit. I will be able to afford some light wheels once my car is paid off. I just need something I can fit a slick on. I don't think I can even afford a skinny right now.
Old Jun 3, 2010 | 11:06 PM
Camaro396's Avatar
It'd probably be cheaper to buy another set of 16x8 wheels to mount slicks on.
Old Jun 4, 2010 | 10:23 AM
Why do you say that? I already ordered the wheels and there is a local that sells take-offs for $30. That was my main reason for buying a 15", the other reason is you get more sidewall with a 15".
