Balancing rear prostars??
Old Jun 4, 2010 | 06:51 PM
Justins00ss's Avatar
Default Balancing rear prostars??
I have a set of 15x10 weld prostars on the back of my camaro and I had to grind the calipers to make them fit obviously. So my question is whats the best way to balance these wheels. I cant put a stick on weight on the inside due to lack of caliper clearance and I really dont want to use clip on weights on the front side of the wheel, so what are my options
Old Jun 5, 2010 | 09:57 PM
kierstyn's Avatar
I think you can do clip on weights on the rear of the wheel. Also when I balanced mine I put the stick on ones to the rear of the wheel and they are still on there.
Old Jun 16, 2010 | 12:58 AM
IWGF's Avatar
You can do clip ons in the back, and I got stick ons in my 15x8s when I had them, so you should be able to get them on w/ the 15x10s.
