Going to pull off 20s on my Z !!!!
Old Jun 7, 2010 | 10:31 AM
Nastyc4's Avatar
Default Going to pull off 20s on my Z !!!!
I'll reveal details when I actually have them in my posession but I am psyched about these wheels !! I have a few ideas on how to make them not look as big and will be going tiny on the tires to keep overall diameter under 26" so they're the same as the 275/35/18s I have on there now. I am not a fan and never have been of 20s on an f-body sure on a c5/6 but I think I can make them work. They are my favourite wheel in the finish that I've always loved and couldnt pass them up for the price.
I'll spill the beans as things progress....
Old Jun 7, 2010 | 07:19 PM
peterlawl84's Avatar
Hope it works out, I get compliments on mine all the time....how short of a sidewall are you going?
Old Jun 7, 2010 | 07:30 PM
SRfastZ's Avatar
pics ?????
Old Jun 7, 2010 | 07:33 PM
sneaky7980's Avatar
i think this is going to get interesting.
Old Jun 7, 2010 | 07:53 PM
BLCKBRD's Avatar
I would say that a larger tire sidewall will make the rim look smaller, opposite of what you said. But that's just my opinion, I'm interested to see pics.
Old Jun 7, 2010 | 09:35 PM
Empatho's Avatar
+1
but I still want to see some pics...
Old Jun 7, 2010 | 09:41 PM
black_sheep454's Avatar
Pics plz
Old Jun 8, 2010 | 12:01 AM
Nastyc4's Avatar
Pics are coming soon I promise. Finalizing stuff like offsets etc if I need to order longer studs and drm billet spacers. Wheels will make their way to me and when they get here I'll post tons more. I'll put up current ones as soon as I have them in my posession. They are actually 19/20.
Sizes I'm looking at now are 263/30/19 and 295/25/20 both are under 26" with the rears .5 bigger. I don't want the rears too much taller and have the car higher off the ground but I need the sidewalls as similar as possible for my tastes. Teaser pics to come Tom !
Old Jun 22, 2010 | 09:41 PM
IWGF's Avatar
Piktars?
Old Jun 22, 2010 | 10:12 PM
damn man, I run a 30 on the rear and thats not much rubber...
Old Jun 24, 2010 | 01:37 AM
ghost_ride_the_whip's Avatar
i run 30 or 35 on my 20s 25 seems too small....... but your choice
Old Jun 24, 2010 | 07:40 AM
1993 z28 f1's Avatar
Hey:
I don't know if you have ridden in a perfomance car with those sidewalls but traction blows and the ride sucks.
IMHO I would strongly suggest a bigger set of tires.
I did this, and was a huge waste of money on my part, as I had to buy tires twice before I had planned as it ruined the cars performance totally. No sidewall means, no traction and no rim protection = bent rims hitting any hole in the road. I thought I could deal with it, my car has the very best Adj suspension and the ride went from awesome to awful. I have now went with 275 40 20 front on this car and 315 35 20 rear and its way better than with the rubber band tires. As I had already BFH, rolled, tubbed, and trimmed for larger tires/wheels. Its got more ground clearence, about the same as stock but looks way lower due to the F-1/RS ground effects, and closer wheel wells with the bigger tires/wheels.
Just a suggestion, from My experience, choose wisely.
Good Luck with your choice.
Dub
When In Doubt Do Without
Old Jun 24, 2010 | 05:00 PM
Originally Posted by 1993 z28 f1
Hey:
Dub
this guy knows what hes talking about, went through the same thing. hey do you mind posting pics of your car, i wanna see what a 40 looks like
Old Jun 24, 2010 | 07:39 PM
Hey:
These are the only pics I have with me, as I am not home att.
These were taken as I was getting the car ready for stowage to go overseas for a year. The wheels are waxed, tires sprayed with a dryrot preventive spray.
Dub
Attached Thumbnails Going to pull off 20s on my Z !!!!-dsc0046622.jpg   Going to pull off 20s on my Z !!!!-dsc0046722.jpg   Going to pull off 20s on my Z !!!!-dsc0046822.jpg   Going to pull off 20s on my Z !!!!-dsc0046922.jpg
Old Jun 24, 2010 | 09:53 PM
looks like the tires in the back barely fit? any rubbing? what size are yours rims, mine are 20x10 so i was going to go 275/35/20 or 285
Old Jun 25, 2010 | 07:00 AM
Hey:
In the pic above 275/40x18 on 9.5x18, front wheels, and 315/35x20 on 11x20 rear wheels this is what started the mod list, to make it all work, I thought I had the newer pics that Showed the newer wheels/tires but I guess not.
20x9 frt, and 20x13 rear now. Was 4 20x11 till they were modded, I just wanted to see if I could make them work, they are very heavy and almost not worth doing for all the time and money in them. They did rub but all the mods done was to stop that, now they only make a slight touch nowadays when at crazy angles side to side like offset of camber driveway when in a left turn in the front. You need a hi heat gun in the front to mold the plastic so they do not always rub. I also needed offset tubular LCAs to fit the rears, besides the lip rolling, mini tubbing, BFH and a little trimming. My Daily Z has 18x10.5 all around, with 285 35 frt and 285 40 rear nitto 555s and rides as good with none of the issues this took to make work. I was pretty bummed after all the time spent on making this work with the 1st set of tires and it sucked so bad, traction and ride wise, I almost gave up. The 20x11 may have worked up front but needed a spacer because of the offset. The tires height was making contact with the top of the inner fender well. Then I found that the BMW x5 had the size tires I wanted to try so thats whats on there now. When I did this back four years ago tire selection blew and they were the only size 20" C5 Z06 rims and tires out. I may try some more tire combo's when I get home.
Dub
Old Jun 27, 2010 | 03:50 PM
Hey:
Nastyc4 how is your progress on this?
Dub
Old Jun 27, 2010 | 11:26 PM
pics????
Old Jun 30, 2010 | 09:27 PM
Nastyc4's Avatar
Hey sorry guys lost this thread for a bit. A lot has changed. I ended up selling my 01 Z so I could get a c5 and slap them on since thats what staggered look best on imo. BUT I ended up picking up a SWEEET ss and it has the rear valance and centre exhaust which really convinced me I can probably pull it off in the rear now theres a semi skirt to help out with filling space.
Ive ridden on 25 series before. My c4 has 315/25/19 rear and 265/30/19 fronts and ive gone 210 mph on the street with them. doesnt bother me one bit. I always pump the pressure a bit higher so I dont kill my rims and I havent dented one yet. the suspension is a little archaic on the fbody compared to my c4 and I am considering a 30 series rear.
First I need ground control coilovers (625/200 spring rate) to keep the ride low and stiff enough not to bottom out constantly. then Ill slap them on. The wheels did just arrive today to me so Ill get pics up soon !!
Old Jun 30, 2010 | 11:20 PM
Nastyc4's Avatar
Hey:
Dub
Thanks for the input. i did alot of thinking and your post and pics really helped. I decided 25 series for the rear IS way too small. I wont be able to tuck in like bimmers etc who run those sizes and a small tire with any gap will make the car look like a 4x4 still.
Im now leaning towards 265/30/19 front. 285/30/20 rears. front rims are 9.5 rears are 10 as per HRE vin I checked.
