Possible problems with this tire combination?
Anyways, I'm wondering how a 26.1" tall front tire is going to look with a 25.79" tall rear tire? (0.31 difference) Am I going to even be able to tell there is a difference by looking at them? Is this going to throw an abs light? Does anyone know if the 555r's still run narrow? I like the 315 555r's because the 315 Mickeys are just a little too wide for my tastes.
I'm open to suggestions for a different front tire if anyone has any. It's taking me forever to decide on tires, and I'm just ready to get these wheels on already.
Thanks
I'm still a little confused on tire sizing. I still wanna go with the 275/40r17 Fuzion up front because it has a similar tread pattern to the 315/35/r17 555r. I just don't want the fronts to appear taller or have a taller sidewall than the rears.
Overall diameter of the Fuzion 25.7". Overall diameter of the Nitto 25.79"
Noob question and I'm probably over thinking it.
Why not go with Nitto NT05 275/40ZRx17", 25.59" up front and NT05R p315/35Rx17",25.71" in the back. I think it looks better and will probably out perform the combo you had listed as well. The regular NT05 315/35ZRx17 is 25.55" and would probably work for 90% of what you want from a tire combo. Just putting out some options for you to ponder. From My Experience the NT05 is Nittos' best tire, not the 555.
Dub
Tire 1 - 275/40R17 Tire 2 - 315/35R17
Section Width: - -
Section Width: 10.82 in 275 mm
Section Width: 12.40 in 315 mm
Rim Diameter: - -
Rim Diameter: 17 in 431.8 mm
Rim Width Range:
Rim Width Range: 9 - 11 in
Rim Width Range: 10.5 - 12.5 in
Overall Diameter: - -
Overall Diameter: 25.66 in 651.76 mm
Overall Diameter: 25.68 in 652.27 mm
Sidewall Height: - -
Sidewall Height: 4.33 in 109.98 mm
Sidewall Height: 4.34 in 110.23 mm
Radius: - -
Radius: 12.83 in 325.88 mm
Radius: 12.84 in 326.13 mm
Circumference: - -
Circumference: 80.61 in 2047.4 mm
Circumference: 80.67 in 2049.0 mm
Revs per Mile: -
Revs per Mile: 810.6
Revs per Mile: 809.9
