Tires
Old Jul 31, 2010 | 06:37 PM
Disturbedtransam's Avatar
Default Tires
I have a 98 Trans Am. I just went and changed my oil and I noticed that both of my tires on the front are worn all the way down to the steel belt on the inside of the tires. I dont have the stock set up in the front. Only mods are Edlebrock IAS Coil overs not sure if that would change or cause this.
Old Jul 31, 2010 | 10:08 PM
MNBlade's Avatar
Usually the cause of unevan wear on the inside is from an alignment issue. I don't think the coil over would cause this. Is it lowered? If it is and it wasn't aligned all the angles will be off.
I would say start with getting the alignment checked and then go from there.
Good luck
