What are you running?
Old Jan 22, 2004 | 03:55 PM
Turbo 1LE's Avatar
Question What are you running?
I just installed some Nitto drags what psi should I run at the track?
Old Jan 22, 2004 | 10:45 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I had good luck running my BFG DRs at about 16psi.
Old Jan 22, 2004 | 11:45 PM
Assassin's Avatar
I run my BFG DR's at 12psi but I'm not sure if the nitto's have a stiffer side wall, try them at 20psi and if you get spin try the 16 then 12, probably shouldnt go lower than 12, btw, how much horse power are you puttin down?
Old Jan 23, 2004 | 05:52 PM
Turbo 1LE's Avatar
The car gets dyno tuned Monday. It's a single T77 with 10 pounds of boost and the largest cooler I could fit. 355/9 to 1/stage 3 CnC ported heads/LS6 port matched intake and everything else you could think of. I'm hoping for some good #'s.
