Torq Thrust backspace and offset
Old Aug 13, 2010 | 05:37 PM
Asian LSX's Avatar
Default Torq Thrust backspace and offset
I've been searching and no luck. I need to know the backspace and offset I need for some 17x9.5 torq thrust IIs to fit my T/A.
Old Aug 13, 2010 | 07:48 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
American Racing TT-2's +45 mm
With 17"x11"s there is always a possibility of needing the BFH and/or fender rolling mods with 315s. If lowered, an Adjustable Panhard Bar becomes a virtual necessity. Some have used the +38 offsets with an 11" wheel but it does stick outside the fender and is definitly not recommended on lowered vehicles. +50 and +56 are the two most common. +50 is the better fit (for the ZR-1 replica).
https://ls1tech.com/forums/wheels-ti...must-read.html
Old Aug 13, 2010 | 08:39 PM
blackls1ta00's Avatar
summit racing is the cheapest far as i know
Old Aug 13, 2010 | 09:27 PM
Asian LSX's Avatar
5.5 backspace and +6mm, will these work?
http://www.summitracing.com/parts/ARE-CL2057956155/
