Bolt pattern and back spacing.
Old Aug 30, 2010 | 10:41 AM
Fun-Formula98's Avatar
Default Bolt pattern and back spacing.
If I were to buy some weld racing rims, what is the bolt patter and back spacing I would need.
Thanks,
Ross
Old Aug 30, 2010 | 11:01 AM
3rdgen92maro's Avatar
If your running a stock length rear in your car to run 15x8 welds you will need a 5.5" backspacing, for 15x10 you will need a 7.5" backspacing and for the fronts 15x3.5 you will need a 1.75" backspacing and the bolt pattern im pretty sure is 4 3/4.
Old Aug 30, 2010 | 04:22 PM
Tank you Sir!
