MT D/R Flat
Old Nov 28, 2010 | 01:33 PM
Mguncowboy's Avatar
Default MT D/R Flat
I recently switched to MT D/R's (305/35R18) and after only about 150 miles I've picked up a piece of metal in the center of the tread. Can a D/R be reliably patched? Or am i about to spend another $300 for a new one?
Old Nov 28, 2010 | 01:36 PM
blk/slvr02ss's Avatar
No it is fine to put a patch on them but would not have it plugged !!!!!!!!!
brokenfly's Avatar
patch it like any other tire...
Old Nov 28, 2010 | 08:32 PM
Mguncowboy's Avatar
I def wouldnt have it plugged. Was just wondering if due to the difference in construction and the thinner layers of rubber and radial plys if a patch would be posible or even hold due to the added tire flex due to lower pressures and launches.
Old Nov 28, 2010 | 08:43 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
They make tire plugs which goes in from the inside. Looks like a tire patch with a plug in the center. A good tire shop should be able to do this for you.
I would worry that a normal tire plug may pull out.
