offset question
Old Dec 11, 2010 | 09:18 PM
vogun16's Avatar
Default offset question
ok i found a set of wheels i really like.. only problem is that they have a 13mm offset in the front and a 14mm offset in the rear... im not too gett with offsets... does that mean i can just get a 25mm spacer and it will bring them out to a 38mm in the front and 39mm rear??
Old Dec 11, 2010 | 10:08 PM
LPE 403's Avatar
highly unlikely, but what are the wheel sizes? couple stickies that should help with your offset questions.
Old Dec 11, 2010 | 10:25 PM
vogun16's Avatar
18x8.5 front and 18x10 rear
Old Dec 11, 2010 | 10:54 PM
99Bluz28's Avatar
Sorry but those won't work, they would already stick out to far, adding spacers would only make them stick out more.
Look for offsets from +35 to +80, any within that range will/can work.
Old Dec 13, 2010 | 09:38 AM
vogun16's Avatar
Will a 18x8.5 with a 35mm offset in the front and a 18x9.5 with a 35mm in the rear look ok? How will they look?
Old Dec 13, 2010 | 11:50 AM
99Bluz28's Avatar
Should look fairly flush with the fenders, you'll probably need to roll the rear fender lips.
