255/50/16s rubbing.
Old Dec 31, 2010 | 05:04 AM
Elthesh's Avatar
Default 255/50/16s rubbing.
My 99 Trans Am came with Corvette C4 rims on it. The 84-87 style. The tires are 255/50/16s all around. I just noticed today when I turned my wheel in to remove a screw in the tire that both sides(right and left wheels) were rubbing when turned inward. They were rubbing on the front of the wheel well. It wasn't exactly bad, but when turned in, the edge of the tire sits right on the inner fender/wheel well.
I'm in the process of replacing the rims with the proper Trans Am rims, but am wondering why such a minor change in tire size is causing this. The Vette rims/tires do seem to, I dunno, stick out more than the factory rims on my old 99 Z28 did. The tires were on the car when I got it too. I do not know if the rims are the 8.5 or 9.5 versions or even how to easily figure that one out, if it even matters.
Another question... The fronts are in need of replacement. If they are going to rub, I would just like to go back to the factory 245/50/16 size. Would those fit on the C4 rims if I don't find factory rims to my liking before I get the new tires? I know the C4s originally came with 255s and the sidewalls on the Goodyear/Sumitomos are almost flush with the side of the rim as it is.
Old Dec 31, 2010 | 09:43 AM
1LOMARO's Avatar
Might have something to do with the offset of the wheels. Here are the sizes that came in 84-87 and their offsets.
front 16"x8.5" 32mm (6.0" backspacing)
rear 16"x9.5" 38mm (6.7" backspacing)
if they are the 8.5" wheels I believe a 245 will be ok... on the 9.5" you will be stretched.
Old Dec 31, 2010 | 12:15 PM
The Mighty Texan's Avatar
Yeah i believe it would have to be the offset too cause im running the same size tire, absolutly no where near rubbing!
Old Dec 31, 2010 | 01:24 PM
Elthesh's Avatar
That sounds about right. Gonna have to put some overtime into finding some factory rims then.
Old Jan 3, 2011 | 04:48 PM
SSCamaro99_3's Avatar
I know you did not put those wheels on there, and glad you are changing them. I bet they look aweful on your car. I wonder what the previous owner was thinking.
