Need Help with Spacers
Old Mar 20, 2011 | 03:52 PM
MillerTime85's Avatar
Default Need Help with Spacers
Put 1 inch spacers on back wheels.Driver's side sits flush with fender but passenger side is almost 3/4 in from fender.Car is lowered with prokit and C5 rims.Tried swapping rims but offset is same on all rims.Doesn't look like car was ever in a accident.Any ideas?
Old Mar 20, 2011 | 04:13 PM
guy7bmwm83's Avatar
My truck was the same way too. And back when it was lowered, the axle was more noticeably off centered from the edges of the rear fenders. I think that is common. I used to be on a Toyota Tacoma forum and all the 2wd guys had the same issue. As long as you don't get vibrations, you should be fine. I have had the truck for 10 years and there are no issues with it.
I also put 1" spacers on the rear, https://ls1tech.com/forums/wheels-ti...cers-pics.html, but didn't notice the axle off center.
Old Mar 20, 2011 | 05:26 PM
LPE 403's Avatar
adjustable pan hard rod...
Old Mar 20, 2011 | 06:45 PM
No vibrations but I also have a wheel hop issue.Will Adjustable pan hard rod fix that as well or also need LCA? and which ones do you suggest?
Old Mar 20, 2011 | 08:32 PM
19xtreme99's Avatar
what f***nuts said
Old Mar 20, 2011 | 08:33 PM
19xtreme99's Avatar
adj. LCAs only center the rear front to back. Your problem seems to only be left to right and an adj. PHB would definitely do the trick. I got mine from Founders Performance FWIW
Andddd.... after reading more closely, get some LCA relocation brackets with your LCAs to decrease wheel hop
Old Mar 20, 2011 | 08:53 PM
armintheman's Avatar
yup i had the same issue and it was because of the stock phb. i purchased a double adjustable one and it fixed that problem.
Old Mar 20, 2011 | 10:18 PM
Would I be ok with a Single Adj. or do I need to get the double?
Old Mar 21, 2011 | 01:01 AM
02WS6SSZ71's Avatar
Single adj would be fine...I would spend the money to get an on-car adj one or you're gonna put it on and take it off 20 times before you get it where you want it.
Old Mar 21, 2011 | 06:44 AM
Good call.Thanks guys
Old Mar 21, 2011 | 07:57 AM
WarShrike's Avatar
Yup, adj. PHB is needed. You lowered the car, but that panhard is still the same length. That changes the geometry of the triangle essentially. Hypotenuse (PHB) is still the same length, but the base is now longer and the height is lower due to the drop springs. This shifts the axle to the driver side.
