wheel size
Old Feb 18, 2004 | 05:56 PM
b01z28's Avatar
Default wheel size
Hi, my name is bill and am a new member from Rochester n.y. I was wondering if any of you guys could tell me if i can put a 285 40 17 on a 10 in wheel on the back of my camaro with out having to make any modifications, and if i can what offset would i need thanks
Old Feb 19, 2004 | 07:46 AM
Xsta Z 28's Avatar
Should fit fine. A 285/40zr17 tire is a tad bit talled than stock but realy shouldn't mess the speedo too much. On a 10" wheel, should fit OK aswell. Offset fot the wheel anywhere between 38 and 50 mm.
Old Feb 24, 2004 | 06:27 PM
noah98SS's Avatar
i have the 285/40/17 nitto's on 17x11 zr1's until they wear out then on to the 315's so yes the 285 will fit a10" rim
