16"max tire size?
Old Mar 31, 2011 | 05:32 PM
gallo-lo's Avatar
Default 16"max tire size?
whats the tallest and widest tire ,i can fit on my f-body? 16x10 rear wheel 7.5 bs.
Old Apr 1, 2011 | 01:57 AM
Mr.z/28's Avatar
Did you widened your 16s??
stock wheels are 16x8, not 10s
Old Apr 1, 2011 | 10:02 AM
Paul 1953's Avatar
just a question..
Do you want wider tires for looks or performance?
I've still got 16/245s with GY Eagle F1 GSD3s . They've had EXCELLENT traction wet or dry. It's only since I cammed the car that I've been able to chirp the tires a little without big effort while letting out the clutch. I'm really enjoying that sensation right now. If I went wider, I'd loose it (unless I went to cheap tires)
Sorry, this doesn't answer your question.
Old Apr 1, 2011 | 04:56 PM
1gt2nv's Avatar
255/50/16 is what I'd run. Just to be safe. I'm sure you could make something wider go on, but would be very unsafe.
Old Apr 1, 2011 | 05:04 PM
Deviant LS1's Avatar
People fit a 325/50/15 without too much work. Do they make a 16" DR in a similiar size?
