Which profile 275?
Old Apr 6, 2011 | 02:54 PM
camaro_geek's Avatar
Default Which profile 275?
I'm looking at picking up a set of oe 18x9.5's. The calcs are that a 275/35/18 is 0.07" smaller total diameter (-0.28% vs stock) and 275/40/18 is 1.02" larger (+3.83%). The 35's are closer to stock but I see a lot of people here run the 40's. Is there any advantage/disadvantage to either size? Car is lowered about 1.25" on Strano springs with konis. Thanks.
Old Apr 6, 2011 | 03:21 PM
chuk23's Avatar
I'm running 275-40 front 295-40 back.
Old Apr 6, 2011 | 03:30 PM
egott_91's Avatar
I have 275/35-18's up front and 295/35-18's in the rear. I also have the Koni/Strano setup. Springs were new in this pic and have since settled quite a bit. Hopefully they fully settle this summer.
Old Apr 6, 2011 | 04:30 PM
Empatho's Avatar
Do the fronts ever rub?
I hope my front springs settle in a little bit two, because the gap on the front is larger then the back But then again I did remove some weight from the front.
Old Apr 6, 2011 | 05:37 PM
Xsta Z 28's Avatar
275/35R18 definitely.
