Spacer Question
Whats the biggest spacer I can safely use with the stock wheel studs? I tried a 5/16 and it was too much so I was wondering if I anybody knew the answer to this....
https://ls1tech.com/forums/parts-cla...l-spacers.html
to be safe, get longer studs and/or adapter/spacers like Carlos is selling. If you still want to use your lug nuts, make sure the additional length to the studs is the same as the spacer you'll be using...
