front fender rolling?
Old Jun 16, 2011 | 02:15 PM
Fast98Z's Avatar
Default front fender rolling?
Soon I'm Planning on lowering my car, just got all new shocks and springs waiting to be put in. My rear fenders already rub so I'm using a fender roller to get them set... but when I drop the car will my front tires rub? Is it even possible to roll the fronts? I just want to know in advance. I'm running 17 x 9 american racing rebels with 245.40.17s all 4 corners. Also when I drop it 1.5" will I have to grind the bump stop? Thanks
Old Jun 16, 2011 | 08:33 PM
VinR1's Avatar
No, you cant roll the fronts. Theyre plastic/urethane and theyll crack
Old Jun 16, 2011 | 09:24 PM
PERFECT Z28's Avatar
All depends on your backspacing, but if it's within reason, you shouldn't rub with a 245 up front...
Old Jun 16, 2011 | 10:33 PM
SparkyJJO's Avatar
245 is a stock width tire. How are you rubbing in the rear?
Old Jun 16, 2011 | 11:38 PM
sixvi6-camaro's Avatar
245's are narrow.. you must have some weird offset rims for those to be rubbing at stock height. as others said fronts are all plastic so no rolling possible you will have to live with the rub or a bit of negative camber to keep them off the fenders.
Old Jun 16, 2011 | 11:45 PM
carlos64030's Avatar
You obviously have the wrong set of wheels on your car if you're rubbing with such a tiny tire. I say you should ditch those wheels and start over from scratch. Post some pictures of your setup.
Old Jun 17, 2011 | 12:35 AM
Latch's Avatar
Damn, is this your car...?
Just kidding! But in all seriousness, you've got the wrong offset if 245s are rubbing either the fender or the bumpstop. Oh and 245s are going to look a little stretched on 9" wide wheels.
Old Jun 17, 2011 | 01:51 AM
01ssreda4's Avatar
Roll the fronts and let us know how it turns out
Old Jun 17, 2011 | 09:35 AM
Xsta Z 28's Avatar
A little heat and they'll bend . . . geez how low are you going? . . .
Old Jun 17, 2011 | 02:18 PM
Undertow74's Avatar
WTF?!?!!!! Is that guy using like a 2in spacer those tires dont look any bigger than a 315 if that and they stick out like a monster truck.......what the hell are people thinking....
Old Jun 17, 2011 | 02:33 PM
Latch's Avatar
It's an epic offset fail.
Old Jun 18, 2011 | 04:39 AM
thecobrahunter's Avatar
L..O..L. Give me a fukkn break!!!
Old Jun 18, 2011 | 06:14 AM
leadfoot4's Avatar
He's going after the late 60s, "pro stock" look........
Old Jun 18, 2011 | 08:49 AM
Fast98Z's Avatar
I apoligize, I meant 275 all the way around, stock height, and I don't know the offset
