15x8 Draglites
Old Feb 28, 2004 | 12:03 AM
ls1camaross's Avatar
Default 15x8 Draglites
Hey I'm looking at buying a set of 15x8 Draglites for the back. But I have a couple of quetions though. What size should the back spacing be? Do I need to run a spacer? What size is the bolt circle?, Am I going to need longer studs? Should I be able to use the 90 Series wheel or do I need XP forged 191 series? I know it's a lot of questions but I dont' want to order anything wrong or order more than once. Thanks.
Old Feb 28, 2004 | 10:31 AM
Casper9T9's Avatar
You can run the 90 series with a 5.5" back spacing. You will have to grind the calipers for them to fit. You can run a 5/16" spacer to cut down on the grinding if you want. The bolt circle is 5-4.75". ARP studs would be nice, but alot of people use the stock ones.
Old Feb 28, 2004 | 12:00 PM
Alright, cool thats what I needed to hear. Now that I'm at it what about the fronts? I'm looking at a set of 15x4's.
