tire size question
Old Jul 21, 2011 | 01:11 PM
stanggreg90's Avatar
Default tire size question
Need to get some drag radials for my trans am and wondering what tire size i should go. Car has 12 bolt with 410 gears, 6 speed car, was looking at 295 45 17 mickeys. Is that to big of a tire? car is making 440 horse
Old Jul 22, 2011 | 11:16 AM
bumpp
Old Jul 22, 2011 | 06:33 PM
ls1curt's Avatar
According to a tire size calculator that would equal a 27.5"x11.6" tire. I think that would be a pretty sweet tire and would hook up better than a 26" tire imo. I was running a 28" tire with a six spd and 460rwhp and it was good. I'm sure you will be putting more power to her in the future anyway. It will also fill the fender gap nicely.
Old Jul 23, 2011 | 09:50 AM
Tommyv8's Avatar
What tires are on the car now? And do you know what speed you're going when you turn 3000 RPM in 4th gear? Double that and that's how fast you're going at 6000 RPM, about where you want to trap (taking it up to 6000 in 4th on the highway be a little dangerous). If that speed is higher then your trap speed then you want a shorter tire to get the RPM up faster and maximize performance. If that speed is slower than your trap then you'll need a taller tire to avoid running out of gear.
