Help with 18" wheels
Old Mar 31, 2003 | 05:05 PM
99TAMedBlue's Avatar
Default Help with 18" wheels
I would like to get 18" wheels. Would 18x11's fit in the back? If so what would be the correct offset? If not what about 18x10.5's and what offset? The fronts I would like 18x9.5's if that will work what offset to get? The car is a 99 Trans AM with Eibach prokit I would like to run 295/35/18 and 265/35/18. Please post with lot's of helpful info. I would like to order this week. Thanks in advance.
Old Mar 31, 2003 | 05:20 PM
Xsta Z 28's Avatar
Default Re: Help with 18" wheels
18" x 9.5" anywhere between a 45mm to 50mm offset and 275/35ZR18 tires
18" x 10.5" again anywhere between 45mm to 50mm would be ideal, and 295/35ZR18 tires would fit.
You can run bigger offsets, but 1, the wheel will move inward, and 2. may increase and/or cause inner wheel well rub on the rear tires.
Just FYI.
