Front Wheel Spacer
Old Sep 14, 2011 | 08:31 AM
WS.666's Avatar
Default Front Wheel Spacer
I just installed all new adjustable front suspension. After my alignment my wheels are tucked a little further into my wheel wells than I like. I'm thinking some spacers will fix my issue. How big of a spacer can I SAFELY run on the front. I was thinking 1/4" or 1/2", I just don't want to have only a few threads of the lug nut on the stud.
Old Sep 14, 2011 | 08:47 AM
Xsta Z 28's Avatar
1/4" tops with out longer studs . . . best to attempt to find a hub/wheel centric one.
Old Sep 14, 2011 | 09:28 AM
WS.666's Avatar
I guess I need to do some measuring, cause 1/4" isn't enough, but 1" might be too much.
Where would I get longer studs? Part numbers from Jegs or Summit?
Old Sep 14, 2011 | 09:41 AM
Deviant LS1's Avatar
I also had this problem. With the adapters in the back the rears sit flush with the fenders. The fronts appeared too far tucked in.
I used the Eibach Spacer kit 90.6.15.003 It comes with two 15mm(1/2") spacers and Grade 10.9 longer studs. They hub centric and wheel centric. I got the info about the spacers in this threads https://ls1tech.com/forums/suspensio...ll-w-pics.html
Old Sep 14, 2011 | 09:03 PM
69TA's Avatar
what ever you do don't run any spacers with the stock studs...they are garbage and will
break off real easy.
get ARP's extended studs.
if you need help
I have some ARP's and spacers that I can sell you.
Old Sep 14, 2011 | 09:05 PM
WS.666's Avatar
if you need help
Thanks, I'll get back to you on that one.
