Rear tire width question
Old Sep 21, 2011 | 12:58 PM
IronwolfWS6's Avatar
Default Rear tire width question
Vehicle is a 99 WS6. I'm thinking about picking up a set of C6 wheels, 18X9.5 in the front and 19X10.5 in the back and I'd like to get some 315's in the back. Right now I've got 17X9.5 TT II's all the way around and I run 315's in the back with NO problem and no spacers or anything. Am I going to need a spacer or what? I'm kinda uneducated about how this works, but I want to make sure I'm doing the right thing before I pull the trigger on this deal.
Old Sep 21, 2011 | 01:26 PM
MasterTomos's Avatar
The reason you're not running into problems with the 315's is because the current rim is too small for them. When you get it on to a proper sized tires, you're more likely (still not garaunteed) to have problems.
I have 17x11's and 315s on my car and have only minor clearance issues (bumptops).
Not sure about 19's, id assume there will probably be issues.
Old Sep 21, 2011 | 01:57 PM
Makes sense. What if I threw some 295's on the back? Still pretty wide, but do you think I'd still have clearence issues?
Old Sep 21, 2011 | 02:28 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I have 295s on an 18x11, and I had a few clearance issues (bump stops, inner wheel wells, and rolled the fenders) - that's because I'm lowered, and the wheel offset of my CCW SP500s tucks them in pretty far.
So a lot will depend on how low you want to go and the wheel offset. If you don't mind the goofy looking tires hanging out beyond the fenders look, you won't have a problem. You'll also probably never need to roll your fenders if your car sits like a 4x4, you never take corners hard, or a combination of the two.
Old Sep 21, 2011 | 02:34 PM
I might end up lowering it 1 inch around one of these days, but I haven't figure it out yet. And my tires stick out a little bit now, but they don't go past the fender lip, so it looks good.
Old Sep 21, 2011 | 05:51 PM
9WhiteCamaro9's Avatar
What I would suggest would be to pick whatever you want weather it be the wheels, tires or both, bolt everything up and see what you need from there. Since I have been on here and from what I've seen, it also depends on the car cause I have heard stories where some didn't have any problems at all and some sounded like they have to redo the whole rear end just for it to fit.
Old Sep 21, 2011 | 06:11 PM
salemetro's Avatar
Buy a Wheelright, measure, and KNOW what is going to fit...or not fit.
http://www.summitracing.com/parts/PHP-01201
Some people don't mind spacers...I can't stand them, personally. To each, his own.
