Fitting 19" c6 wheels in the rear??
Old Oct 26, 2011 | 10:15 PM
miller white's Avatar
Default Fitting 19" c6 wheels in the rear??
Tried doing some moching up tonight can already tell some cutting is gonna be in the near future. Anyone else out here try running these?
Old Oct 27, 2011 | 02:45 AM
artic99z28's Avatar
if ur talkin about camaro/firebird then yes i run a 315 40 michelin pilotin the rear with c6 5 spokes all i needed was a 1 1/8" thick spacer the one i got is a topline part # 54755475 solid aluminum bold on spacer with studs pressed into it and the wheel bolts to that no cutting or anything i still have 1/8th inch gap betwene the bump stop bracket
Old Oct 27, 2011 | 08:11 PM
BandDirector Blk98ZM6's Avatar
1.25" 5x4.75 adapter/spacer and 275/30/19 or 285/30/19 tires will fit F-Bodies with no rubbing or cutting required with the stock C6 19x10 OEM rim w/79mm offset...been there, done that, ride was too rough, and I'm back on 18" rims...
Old Oct 27, 2011 | 08:46 PM
at23520's Avatar
tada, 1.25" spacers
Old Oct 27, 2011 | 08:49 PM
69TA's Avatar
I ran 19's with Konis all around and lowered on LG springs
and the ride was not bad.
Old Oct 27, 2011 | 09:20 PM
At the time I ran the 19's, I was on an Eibach Pro-kit, so that may have had something to do with my ride issues, but I also couldn't get traction with a 30 series tire. Combine no traction with a bad ride (very little sidewall on 30 series tire) and that made a believer out of me that an 18" rim is really the largest you should go on 4th Gen. F-Bodies.
I'm on 18" rims now with Strano/Koni set-up and couldn't be happier now!
Old Oct 28, 2011 | 06:46 AM
artic99z28's Avatar
Originally Posted by at23520
tada, 1.25" spacers
^ exactly
Old Oct 30, 2011 | 01:25 PM
97 FiReBiRd's Avatar
Just gunna add something, not trying to hijack, just got 18s and 19's, 1.25 spacer also, but I dont like the way the car sits, so I'm being told that if I drop the car I need to roll the rear fenders?
Old Oct 31, 2011 | 07:37 AM
BOBS99SS's Avatar
Captain Double Post
97 firebird whoever told you that is correct, dont really know what setup you have but that is pretty much a must for these cars when lowering and 18 or 19 rear with a decent size tire
Old Nov 3, 2011 | 12:34 PM
Default LCA's and APHB
Thanks for your opinion, I have been hearing however that an Adjustable Panhard Bar would do the trick as opposed to rolling the fenders, anyone try that and have sucesss?
Old Nov 3, 2011 | 02:18 PM
at23520's Avatar
Mine isn't rolled, nor a adj phnrd bar & is Lowered 1.25" . Doesn't rub
Old Nov 3, 2011 | 08:16 PM
It depends on what size tire you run on 18's or 19's. I currently run 275/35/18 tires on 18x9.5 rims and I have no issues and when I had 19's I ran 275/30/19 tires on a 19x10 rim and again had no issues. I'm lowered 1.25" and my fenders are NOT rolled. Bottom line is as long as you stay with the same overall height (25.6") that the stock tires were and a 275 width tire, you shouldn't have any problems ...some guys can even run 285 or 295 width tire without rolling as long as the rim's offset is correct.
Old Nov 3, 2011 | 09:10 PM
I am running an 18 and 19 setup, just looked at my tires and I'm about to **** a brick thinking about replacing them, 225/50/18 up front, and 285/35/19 in the back......think itll fit? I bought these from a guy on here and they looked good on his car, it just wasnt lowered.....
Old Nov 4, 2011 | 05:13 AM
BOBS99SS's Avatar
Captain Double Post
fixed my post, i meant with a decent tire, im a fan of bigger tires
Old Nov 1, 2012 | 09:53 PM
WhiteLightening01's Avatar
What if I don't want to use a spacer what do I do cuz I just bought some c6 wheels and tires for my trans am
Old Nov 1, 2012 | 10:03 PM
-=Modified=-'s Avatar
Running 19x10s c6 z06 deepbdish on an 02 camaro. The only thing I had to do was add 5/16 * 7.95 mm spacer to correct the offset (65 mm), with 305-30-19. There was no need for longer studs.
Fronts are 18x10.5 with 295-30-18
Old Nov 2, 2012 | 08:34 AM
I've heard that spacers can make ur studs weak and possibly snak coming off the line. So what should I do if I don't want to use spacers its 18x9.5 front and 19x10.5 in rear with front 245/40r18 and 275/40zr19 in rear
Old Nov 2, 2012 | 11:40 PM
Why would you want to do a 275 with a 10.5 wide wheel?
Old Nov 4, 2012 | 06:45 PM
dws6's Avatar
agreed. 10.5 is to wide for a 275. it may fit but it will look rediculous
Old Feb 22, 2015 | 04:18 PM
Adan Ramos's Avatar
Default New to the T/A Family
Just bought a T/A
I just purchase some c6 replicas with 19x10 in the back with +65 offset for my 98 Trans Am, what tires should I get to avoid rubbing? Also, will I need a spacer?
