Which Blizzaks on Z28 wheels?
Old Oct 27, 2011 | 01:14 PM
stingrayj's Avatar
Default Which Blizzaks on Z28 wheels?
I recently picked up a set of OEM silver Z28 "snowflake" wheels for the purpose of running winter tires. I've narrowed my search down to two tires, but I can't decide between them.
The two that I am considering are:
Blizzak WS60 225/55 R16
Blizzak WS70 225/60 R16
The WS60's will be closer to OEM size, but it sounds like the WS70's may be a better tire.
Anyone have experience with these tires? All input is welcomed.
Old Oct 27, 2011 | 08:56 PM
GrimreaperSS's Avatar
You should be happy with either tire. Obviously the WS70 is the next version and should be a bit better. My only gripe about these is that the Winter tire compound is only in approximately the first 1/2 of the tread depth. After that, the compound is the same as any other all season tire. The way I see it, your paying all that money, for only half of the tire....... just my opinion. I understand that the underlying 1/2 of of the rubber compound helps provide stability so that the tires are not entirely "squiggly" feeling. I just know other brands do provide full tread depth winter compounds, without sacrificing stability. Either way, you will still be happy with either the WS60 or WS70.
Old Oct 29, 2011 | 08:33 AM
stingrayj's Avatar
Anyone else want to chime in?
It's snowing right now so I will probably get the winter tires soon.
