sidewall cracks in MT DRs
Other than that, from what I see my other guess would be you guys are running too low of air pressure on the street..25-30 is fine. Maybe 20 psi is even fine, but I would never drive highway speeds with 10-15 psi in them. You will eat the sidewall as if your driving on a semi flat tire. Since they are low profile you wont notice the adverse effects until you air them back up to the correct air pressure.
I have ran MT bias plys that I purchased used, Nitto radials that I purchased used, and MT radials I purchased new. I've never had a problem with any of my tires cracking, but I take good care of them and make sure I run the correct air pressure depending on what Im using the tires for, and I'm also in the tire business so it helps I know what to look for.
