Gonna order wheels and need HELP!!
Old Nov 23, 2011 | 10:50 AM
Guitar's Avatar
I suppose the Nittos.
I'd say you're making a bit more than 330 if you've got full bolt ons, but I also don't know what year your car is.
Old Nov 23, 2011 | 10:56 AM
camaroboy14's Avatar
I am a 2002 camaro ss
Old Nov 23, 2011 | 10:59 AM
whytryz28's Avatar
I had the BFG g-force tires on my LS1 and since you will be driving this daily, I advise to NOT get those.
They wont last you longer then a couple weeks, I was able to get about a week of life out mine (2 track passes and rest daily driving 14+ miles), when they get hot from driving around they leave a feint trail, the compound is super soft and if you hit a puddle you will hydro.
Old Nov 23, 2011 | 11:08 AM
Thanks why try .. I won't get those then .. Great advice .. My last question .. Are the Nitto nt 05 s good performance tires? I had the Nitto 555s and when they where new they hooked good .. Are the Nitto Nt 05 s better? And will a 305 35 18 fit wit little to new mods needed? Please let me know I appreciate the help..
Old Nov 23, 2011 | 11:36 AM
Drokkers's Avatar
i have 275/40 17 front and 295/35 18 rear. no abs in normal driving conditions, a couple times in autoX. Had to BFH the rear a little, my car is lowered and i didnt get the adj parhard bar until a few weeks after the new wheel and tire combo.
Old Nov 23, 2011 | 11:39 AM
Thanks drokkers
Old Nov 23, 2011 | 11:47 AM
whytryz28's Avatar
NT-05 is probably the 2nd best street/track tire right now. Invo would be top and I would get the Invo over anything, sucks there sizes are so limited but they make a 295/35/18
Old Nov 23, 2011 | 11:54 AM
Invo .. What brand ?? Nitto?
Old Nov 23, 2011 | 12:19 PM
djfury05's Avatar
Invo's are junk from what I've read.. they don't last for ****.. go with the NT05's for sure
Old Nov 23, 2011 | 12:28 PM
So nt 05s???
Old Nov 23, 2011 | 01:00 PM
Spd-Kilz's Avatar
For the record I would do this:
265/40/18 front
295/35/18 rear (or 305/35/18)
275/35/18 with those rear tires might make the ABS inop light go off.
Old Nov 23, 2011 | 01:02 PM
  #32
So spdkilz the way you recomend would work with out the light going off? And would those 305s fit easy?
Old Nov 23, 2011 | 01:24 PM
  #33
Spd-Kilz's Avatar
Correct. What you are suggesting will be very close to setting it off (or might actually set it off).
I terms of fitment, a lot will depend on the offset of the wheels. I ran OEM C5 Z06 wheels (18x10.5) with 295/35/18 tires on my Formula, and I had to do a very light BFH. Running a 305, depending on the wheel offset, should cause the same minor problem.
Also keep in mind that Nitto tires are notorious for running narrow.
Old Nov 23, 2011 | 01:40 PM
  #34
Thanks spd kilz...Only thing that sucks is at 305 35 18 is MTs and Nitto Nt 555r avalible at that size so would those nittos hook good ? Also what offset would you recomend thanks so much for the help
Old Nov 23, 2011 | 01:41 PM
  #35
whytryz28's Avatar
My dad has a set on his Viper and they are ******* amazing, last longer then the stock Pilot tires that were on the car.
Old Nov 23, 2011 | 01:46 PM
  #36
Spd-Kilz's Avatar
There are more tires that come in that size. I am running 305/35/18 in Toyo R888. I don't have any experience with how the Nittos will hook.
In terms of offset, if you are buying wheels from any forum sponsor, they should be in the right ballpark. Ideally you would want ones that are very similar to the C5 Z06 wheels - maybe slightly more aggressive.
Old Nov 23, 2011 | 01:55 PM
  #37
Yeah I Am getting them from OE wheels .. And the tires I am getting from summit sense they ship to APOs over seas for free I already asked them so what ever summit racing has I can get .. Love that pic !!
Old Nov 23, 2011 | 03:23 PM
  #38
Spd-Kilz's Avatar
Thanks.
If you are really limited with a selection for a 305, then do the 295/35/18 or a 315/30/18. Both will work well with the front tire I suggested. You can safely put a 315 on a 10.5" wheel. There will a little bit more BFH involved, but it's definitely doable.
Old Nov 23, 2011 | 03:59 PM
  #39
I will do a 305 now I will wait till fri too see if there having any black fri deals .. Hopefully they do .. Thanks so much spd kilz
Old Nov 23, 2011 | 05:01 PM
  #40
PGUFF's Avatar
With only bolt-ons, you will hook just fine with 555r.
