Tire Size Questions ( please help)
Thanks guys 285 will be just a tad taller and wider.
Since I am assuming all four wheels are the same width, I see no point in having different tire widths front to rear, especially only 10 mm. Then you can maintain tire rotations, if desired.
Agreed... I have 275/35/18 in the front and 285/35/18 in the back, but I have 9.5's in the front and 10.5's in the back. If I had 9.5's all the way around I would have gone with 275/35/18's in the back as well.
275 fit with no concerns of OD and speedo calibrations
285 wll fit too, but OD will be just a tad taller, and the speedo will be off, not much though.
Remeber you are only talking about 10mm of width - not much.
