Pre-Planning - Will this fit?
Old Mar 15, 2004 | 02:13 PM
Toonz's Avatar
Default Pre-Planning - Will this fit?
I'm going to be purchasing some Bogart RR10's shortly and want to know if this will work.
16x10 Rim
26x10.5 ET Street
My car has Koni DA's and Eibach Pro Springs so it sits quite a bit lower than stock. Am I going to be have to cut or roll the fenders? Is there a better size tire that I should consider? TIA.
Rob
Old Mar 17, 2004 | 06:30 AM
Fast SS on TNT's Avatar
Nah, that tire should go right on. A 10.5 section width leaves plenty of room. I ran a 26 X 10.0 ET Drag on a 15 inch Weld Draglite a couple years ago, and I had ZERO problems with clearance.
Just double check everything visually, and take the car for a series of slow corners to test everything.
Old Mar 17, 2004 | 07:04 AM
WILWAXU's Avatar
on a 10" rim.. I'd go with 26x11.5's.
26x10.5 is more suited to a 8" rim.
Old Mar 18, 2004 | 04:25 AM
Toonz's Avatar
Ok... but would that require a little fender banging or cutting? I'm getting the car repainted soon and am trying to figure out if I should get my wheels fitted first, just incase. Thanks.
