C6 adapters
Old Feb 6, 2012 | 07:40 PM
stuntinZ28's Avatar
Default C6 adapters
Ok 95 camaro z28 runnin C6 wheels 285/35/19 rear can i use a 1.00 adapter or do i need the 1.25
Old Feb 6, 2012 | 09:02 PM
stuntinZ28's Avatar
anyone tried 1.00" adapters
Old Feb 7, 2012 | 04:08 PM
69TA's Avatar
the space you need depends on the offset
there so many different ones made nowadays.
Old Feb 8, 2012 | 06:26 PM
stuntinZ28's Avatar
the rear is a 19x10 +79 i see alot of 1.25 with rolled fender just wanna know if i can avoid the fender roll
Old Feb 8, 2012 | 06:49 PM
VinR1's Avatar
Either will work fine
Old Feb 8, 2012 | 08:03 PM
69TA's Avatar
if you are not running a watts set up I would recommend rolling your fenders
when the car sways it will move quite a bit from side to side.
I rent the roller tools and heat gun for $40 and it's cheap insurance against slicing up a 3-400 dollar tire.
Old Feb 11, 2012 | 10:54 AM
stuntinZ28's Avatar
thanks but the ole louisville slugger works great lol thanks for the help
Old Feb 11, 2012 | 10:59 AM
MJs1FastSS's Avatar
if you do that might wanna heat of the paint with a blow dryer or heat gun as i have seen a few friends of mine paint crack during the rolling using this method as well as with a professional roller
Old Feb 11, 2012 | 06:24 PM
stuntinZ28's Avatar
most deffinatly thanks for the help
Old Feb 11, 2012 | 11:00 PM
stuntinZ28's Avatar
but will the 1.00 adapters work if i roll fenders is the main question i dont want to rub inner feder at all but wanna keep the tire as far as i can under the car tucking if you will
Old Feb 12, 2012 | 03:40 AM
Blk98Vert's Avatar
The 1 inch should be all you want. It will make the offset a +53.4mm and stock is +56 or +50 so it will remain tucked in just fine
Old Feb 13, 2012 | 09:02 PM
stuntinZ28's Avatar
thanks vert 98 lol what is she doin to that bumper
