Nt05R
Old Feb 15, 2012 | 09:00 PM
verticide's Avatar
Default Nt05R
What would be a good base to start from, when dialing in PSI for NT05R's ? Granted there are numerous variables involved for maximum results, so I will list some data that maybe of use in deciding what a good general PSI starting point might be. (75 deg, 285/40R/18, 421 whp, 4.10 gears, M6,LS1). I would appreciate any advice on this given...thanks. JD
Old Feb 15, 2012 | 10:11 PM
meine96ws6's Avatar
Around 22-25
Old Feb 15, 2012 | 10:40 PM
verticide's Avatar
Thanks for your information...deflating now
Old Feb 16, 2012 | 07:33 AM
alans02z's Avatar
I went to 22 on mine. 60 degrees, 315 35 17, 522 rwhp, 4.11 gear, 408 ls. I dropped down to 20, nothing really changed.
Old Feb 16, 2012 | 06:22 PM
verticide's Avatar
Thanks for the reply, had them put on today, for some reason they are actually shorter in height and sit inside the fender further in, than the stock 275/40/18. I was not too thrilled with the look. I figured the 285/40/18 nt05R'S would be taller and wider. Checked and re-checked the size...any ideas why ? My car looks like a lunar space buggy now with all the gap between fender and tire. Car is lowered on stock bolts now, two threads left. JD
