Prostars/Draglites ?
Old Mar 21, 2004 | 03:11 PM
z28hokie's Avatar
Default Prostars/Draglites ?
I know to fit the 15" on the rear you need to do some grinding. But is grinding needed on the front? (I know the brakes are a little smaller up there).
Old Mar 21, 2004 | 03:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You can run a 15x3.5 Weld rim up front with a 5/16 spacer and no grinding. But if you did grind you would need to knock down the outer edge of the caliper.
Old Mar 21, 2004 | 05:19 PM
z28hokie's Avatar
Thanks John... Even with the spacer there is still plenty of thread for the lugs?
Old Mar 21, 2004 | 05:33 PM
kp's Avatar
kp
nope, just buy a set of ARP long studs. They will still work with the stock capped lug nuts/covers and you will have a lot more thread. They still wont be NHRA legal with the spacer, they come about flush with the wheel, but its a lot safer then stock studs. Takes about 15 minutes to change them, dont even have to pull the rotor or caliper
Found a few pics of how long the studs are, I had to grind my calipers a little with the spacers, a LOT now without them..
