draglites
Old Mar 21, 2004 | 11:57 PM
SSEUL8R's Avatar
Default draglites
what's the right size and backspacing for a set of draglites out back and skinnies in the front? I was lookin at 15x8s or 15x10s. But what is the backspacing supposed to be? I want the widest I can have without having them stick out, and without them rubbing on the inside. They're going to be under a 415rwhp + 150TNT car. I want to run like 26x10.5x15's or so. Then theres the fronts. What size for them? Im just a rookie when it comes to draglites, thanks for the help.
Old Mar 22, 2004 | 09:21 AM
WILWAXU's Avatar
I suggest talking to SJM about Bogarts, but if you are set on getting Welds, here's the BS breakdown:
15x3.5 = standard
15x8 = 5.5
15x10 = 7.5
Fronts will fit with 5/16 spacer. Rears will require you to grind the calipers. Most run them with 5/16 spacers to reduce the amount of grinding.
Old Mar 22, 2004 | 10:30 AM
Derek98z's Avatar
exactly the specs wilwaxu gave. Also need to change to ARP 2.5" wheel studs. The stockers barely stick inside the wheel with a spacer.
Old Mar 22, 2004 | 12:00 PM
Tommy Steadman's Avatar
I received my 15x10 Drag Lites last week and began to do the grinding on the calipers necessary to install the wheel. Some one had mentioned in another post that a lot of grinding was needed to make them fit. I have done alot of grinding and they are still rubbing. Does anyone have a before and after picture of the caliper or even just an after grinding of the caliper picture that could be posted? This would maybe help me to know that I am going in the right direction. My caliper seems to hit mostly at the front center of the caliper. Thanks for any help with this......
Old Mar 22, 2004 | 12:16 PM
95z6spd's Avatar
is that the same for a 1995 z28 as well?
Old Mar 22, 2004 | 02:20 PM
Derek98z's Avatar
No. LT1's have smaller brakes and should clear.
As for the post above regarding grinding, you pretty much have to cut a 45* slice off the front. The better your grinder, the quicker it is. I used a industrial 4" electric angle grinder. It cut right through quickly.
