tire decision?
Old May 29, 2012 | 06:46 PM
9D4Z28's Avatar
Default tire decision?
I have 18x9.5 c6 zo6 rims and I it's time for new tires. I had to 275/35/18 all the way around before. this time I'd like to have a 275/40/18 in the back and a 275/35/18 in front. Im looking for a sticky affordable tire for a college student for the rear. Any suggestions and thoughts? thanks
Posted from LS1Tech.com App for Android
Old May 29, 2012 | 07:25 PM
csess's Avatar
You don't want to mismatch the profile size an keep the same width. Maybe a 245/40 in front with a 275/35 in the rear not sure exactly tho. I think the front/rear stagger info is posted in a sticky somewhere.
Old May 29, 2012 | 07:26 PM
csess's Avatar
Oh yeah forgot....i run nitto 555 an love them
Old May 30, 2012 | 04:20 PM
99Bluz28's Avatar
what tires do you have now, and how do you like them?
BTW, Sticky and Affordable don't mix very well, it's going to be a compromise.
A decent, but affordable tire would be a Falken FK 452.
The 275/35/18s are $163.98 ea., and the 275/40/18s are $150.97 ea..
I've had them before(in those sizes), their a good tire for the price.
Old May 30, 2012 | 07:02 PM
9D4Z28's Avatar
right now i have nexen n7000 they wore out quick after a couple trips to the track. i want to go 285 in the back if i can. do i need spacers? i think its the biggest my car can hold without spacers. how small of a tire and side wall profile should I go in the front if I go 285 in the back? thanks for all your help
Old May 30, 2012 | 09:49 PM
carlos64030's Avatar
A 285 width tire is marginally wider than a 275. No, you won't need a spacer.
Old May 31, 2012 | 06:49 AM
9D4Z28's Avatar
Okay thanks. Now what tire size and profile should i go in the front with a 285 35 in the back?
Old May 31, 2012 | 12:40 PM
99Bluz28's Avatar
I'd go with a 285/35/18, so then you can at least rotate the tires front-to-back and have longer tire life. If you're not lowered you could go with a 275/40/18 size front and rear.
Old May 31, 2012 | 03:46 PM
rudytirerack's Avatar
LS1Tech Platinum Sponsor
Yes make sure the front and rear overall diameter are close to the same.
