Will they rub???
Old Apr 1, 2004 | 07:06 AM
camaroguy98's Avatar
Default Will they rub???
I am running a 18x8 Eagle 077 +38mm offset and was wondering if a 245/45/18 will work or if I will have problems with tires rubbing?? Thanks in advance!!
Old Apr 1, 2004 | 08:31 AM
Xsta Z 28's Avatar
Should be ok, with that overall width. My 9.5" 38mm offset wheels ever so slightly rub up front at full turn lock. Can't hear anything, but you can see a little rub mark on the black plastic liner.
Out back you should be golden. My 10.5" 38mm offset wheels do rub the wheel well lip over bad bumps, but your wheel will be near a 1 1/4" narrower to "one" side so that should clear.
Old Apr 1, 2004 | 08:44 AM
The height of the tire shouldn't be a problem?
Old Apr 1, 2004 | 09:12 AM
Xsta Z 28's Avatar
Post
Hmmm, the tire does seem tall, at 26 11/16" tall. You ideally want to be at ~ 25 5/8"
A 245/40ZR18 would be a much better tire.
