Tire size question
Old Jul 3, 2012 | 07:43 PM
Slider9751's Avatar
Default Tire size question
Could I fit 305/35r18 tires on 18x10 wheels??? The sticky says that 295's are the widest you can go on a 10" wheel, could I get away with the 305's?
Old Jul 3, 2012 | 08:02 PM
hiram007's Avatar
I had 18X10.5 TT2's on the rear of my 99 WS6 (custom size) with 295 BFG's. They fit perfect, sidewall was parallel with the rim. Your talking about a rim that is 0.5in thinner in the rear with a tire that is 10mm wider. I wouldnt recommend it, that sticky is pretty much spot on with what you can and cant do. 295 is probably the widest you can go as listed.
Old Jul 3, 2012 | 08:10 PM
Slider9751's Avatar
ok thank you
