Draglites - Will these Studs/Lugs Work?
I'm thinking about picking up some Weld Draglites to run on the street, 15x3.5's and 15x8's. I know I'll need 5/16" spacers if I want to keep the grinding to a minimum, and since I'll be going with them, I'm guessing I'll need longer studs. Are these the right ones?
113-100-7708 ARP Wheel Studs, 12mm X 1.5, 2.5" length
Also, will these lugs work?
WLD-601-1912 Lug Nuts, Shank with Washer, 12 mm x 1.50 RH, Closed
I know they're not open-ended (NHRA), but I want something that'll look good on the street
BTW, would the Summit lugs work? They've got some with the same specs (12mm x 1.50 RH), but the shank length isn't as long (.580-.800" vs. 1.750"), and the shank diameter is also a little smaller (.679-.687" vs. .740-.745").
TIA :worship:
TIA :worship:
I don't know about Draglites, but my Prostars needed .679-.687 dia to fit. I ordered the weld 1922 which is the same as the one you have listed except with an open end and the diameter was too large. The best thing to do is call Summit and they will help you with your application. I ended up ordering some Summit lugs with 1.38" shank and .678-.687 dia to fit my Prostars.
