For you guys thinking of C/L Warriors.....
Old Apr 10, 2004 | 09:29 PM
02 Silver Z's Avatar
Exclamation For you guys thinking of C/L Warriors.....
For you guys out there thinking of going to Center Line Warriors, (15x10 with 6.5" off-set to be exact) you may have to do a good bit of grinding to get them to fit. I had heard that very little grinding if ANY would be needed for Warriors but the amount I had to grind wasn`t "little". I don`t have my 15x4 fronts yet so I can`t comment on them. I just figured I`d put this out there for people thinking about running them. And if you do go that route, make sure to have the shop mounting and balancing them to put the stick on weights to the far inside of the rims to clear the calipers.
