Which wheel studs
Old Apr 12, 2004 | 10:26 AM
DEEZ98Z's Avatar
Question Which wheel studs
I have a set of 15x10 Prostars... and will be running a spacer. What wheels studs should I get for this? I still want to be able to run my Z06 rims and a closed end lug. Can some one point me in the right direction
Old Apr 12, 2004 | 11:03 AM
SilverGhost's Avatar
Motorboater
if you want to be legal you need the ARP extended studs.
www.ls1speed.com has them, they are cheap.
but they will not work right with street rims, you'll need an open lug and they will stick out some, prolly somewhere even with the rim. I will be having this problem when my 9" gets fixed as I have extended studs and just bought nice street rims, will know what must be done exactly when i put the 9" back in
Old Apr 12, 2004 | 11:15 AM
DEEZ98Z's Avatar
Well do you think that i will be ok running the 1.5" since these are much stronger?
Old Apr 12, 2004 | 11:46 AM
Derek98z's Avatar
The 1.5" work, but it is scary short! I drove like that for a week and wouldn't recommend it. The 2.5" ARP's gave me peace of mind. I am not using open end lugs and these work fine.
But I imagine you must have the open end to run the Z06's
