Offset Pics Please
Old Jan 14, 2013 | 10:33 PM
dws6's Avatar
Default Offset Pics Please
I have been searching and found little info........
I am looking for those of you with 9" front and 10.5" rear wheels that know their offsets. Please post picture with offset and rim width and note if any mods were required.
I will be doing 9x19 with a 265/35 and a 10.5x19 with a 305/30. I was told by the wheel manufacture that a 42mm front and 45mm rear is what i should do but feel that is likely to be too tucked in especially according to the wheel chart in the sticky.
So I am looking for visual confirmation to what I like so I can get these things ordered.
Thanks guys,
Old Jan 15, 2013 | 12:45 AM
99Bluz28's Avatar
I'd stick with the +45 for a problem free fitment in the rear, up front a +35 would work fine.
Old Jan 15, 2013 | 02:32 AM
LPE 403's Avatar
+38 front (9.5) 275/35-18
+19 rear (11.0) 315/30-18 (1" narrowed rear - add the 25mm for a normal rear = +44-ish)
Old Jan 15, 2013 | 06:10 AM
dws6's Avatar
So an equivalent 9" wheel would need to be 32mm for the same fitment, correct?
Do you have a pic down the side to see wheel relation to the fender?
Any others out there?
Old Jan 17, 2013 | 08:01 PM
dws6's Avatar
any others out there?
Old Jan 17, 2013 | 08:52 PM
LPE 403's Avatar
9.0" ..... +38 to +56 mm .... 255, 265, 275
Old Jan 17, 2013 | 09:23 PM
dws6's Avatar
I understand there is a range. 56mm is stock fitment and deffinately dont want that.
if I wanted it to look like your 9.5" with a +38. wouldnt i need to substract the 1/4 differential from the offset (approx 6mm)? for a 32mm???
If i used the same +38mm and the wheels is a 1/2" narrower then wouldnt it sit 1/4" further under the fender?
