26" vs 28" tire
Old Mar 16, 2013 | 05:07 PM
98cobrakiller's Avatar
Default 26" vs 28" tire
trying to decide what drag radial size to go with. is there any abs issues with the abs i have a 3 channel abs
Old Mar 16, 2013 | 05:46 PM
sabersaw30's Avatar
Nos 28 n/a 26. How much power you making? My personal preference is a 275 50 15 on a 8 inch rim for more baggage on the tires.You get more gearing with the 26 also.
Old Mar 16, 2013 | 05:48 PM
BADMOON's Avatar
Default !!!!!!!!!!
x2.. 28 overkill
Old Mar 16, 2013 | 05:51 PM
adamantium's Avatar
^ Pretty much dead on. Im going with a 26inch tire.
Old Mar 16, 2013 | 05:57 PM
mikh338's Avatar
deff a 26 for n/a but if spraying you need the 28 for the extra mph. it also depends on if your auto or m6 and gearing etc...
Old Mar 16, 2013 | 07:04 PM
im a a4 with 3.42 gears. n/a
Old Mar 16, 2013 | 07:31 PM
sabersaw30's Avatar
What kind of converter you running?
Old Mar 16, 2013 | 07:56 PM
stock at the moment but i got a yank ss4000 on my workbench and working on getting my flt transmission
Old Mar 16, 2013 | 09:30 PM
BOBS99SS's Avatar
Captain Double Post
I had no abs issues on a 26,now on a 28 i did,i went with 28s because 26s imo looked to tiny, but the 6s were more than enough
Old Mar 16, 2013 | 09:35 PM
high impact's Avatar
Running 26 et street on mine. M6 3.73 12 bolt. Will switch to 28 when I spray but working fine na at this time.
Old Mar 17, 2013 | 02:59 PM
ElkySS's Avatar
i don't mean to thread jack here but im wondering the same thing but my car makes 502rwhp through an m6. I also have 4.10s. I was trapping 122 before the heads and intake got ported so I think im gonna need a 28' tire. I'm about out of gear as is. what tire size should I go with and not worry about rubbing issues on the street?
Old Mar 17, 2013 | 09:50 PM
1999transamls1's Avatar
I run a 28 with 3.42 rear end with my ss4000 and doubt I'll go to a 26 if anything I'll just change the rear gear
