Help!!!
Old Apr 20, 2004 | 09:18 PM
1QWIKZ's Avatar
Default Help!!!
i have this situation on my hands. i bought some wheels that were SUPPOSED to have a 50mm offset, but after mounting them on my car, the passenger side rear wheels sits out further than the other side. i might be in denial, but i keep telling myself its not the wrong wheel offset . what options do i have ,i doubt i can return them since its been more than 10 days since purchase(bought them in december, but my car has been under construction so i never had a chance to size them up). any info will be helpful, thanks in advance.
Old Apr 20, 2004 | 09:32 PM
ChiefBrody's Avatar
Is your car lowered? Adjustable panhard bar will help.
Old Apr 20, 2004 | 09:37 PM
1QWIKZ's Avatar
no it is not lowered, but eventually i was planning on dropping it an 1' or 1 1/2'. i just want to get the wheels centered. will a adjustable panhard bar have any negative effects on the pinion angle? or will lowering the car be impossible with the adjustable panhard bar?
Old Apr 21, 2004 | 03:56 PM
Xsta Z 28's Avatar
Adjustable Panhard is almost required with lowering . . .
Adjustable Panhard only moves the axle side to side so has no effect on the pinion angle.
Lowering a car effects pinions angle though . . .
Old Apr 21, 2004 | 05:40 PM
1QWIKZ's Avatar
cool, so will that be the most cost efficient way? or should i just buy 1 wheel to replace the problem?
Old Apr 21, 2004 | 10:18 PM
VIP1's Avatar
Copy & Paste Moderator
Have you measured them to verify the offset?
Otherwise, like the others said, an ajustable PHB will help you there.
--VIP1
