Old May 27, 2016, 03:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
4th Gen SS Wheels
Old Jul 7, 2013 | 09:17 PM
libertyforall1776's Avatar
^ Yes that was my thinking as well, so I am mostly ruling out that 17x8.5
18" in that Grand Sport style are:
18X8.5 5X4.75 +56
18X9.5 5X4.75 +40
18X9.5 5X4.75 +57
I assume the bolded one is the best choice overall, as wouldn't a 40mm offset be possible to scrape the wheel wells?
Old Jul 7, 2013 | 10:33 PM
99Bluz28's Avatar
18X8.5 5X4.75 +56
18X9.5 5X4.75 +40
18X9.5 5X4.75 +57
The +40 should be fine, unless the rear-end is way off center. Plus the +40 will give you car a 1.3" wider track then the +56, and the wheels won't look sunk in.
Old Jul 9, 2013 | 01:38 PM
Discount Tire says the 285/35/18 tires won't fit on the fronts, but rear is ok...
I need to find a photo of 18" rims with 275/35/18 tires to see just how narrow that looks.
Originally Posted by 99Bluz28
Going narrower is counter productive; don't do it! In that case it would be worth it for you to move up to the 18 x 9.5 +40 offset wheels. You can run up to a 285/35/18 on the 9.5" wide wheels, but you'll find a better selection of tires and at a better price going with a 275/35/18 tires.
BTW the widest recommended for a 8.5" wide wheel is a 255.
Old Jul 9, 2013 | 10:25 PM
Robbie Wilson's Avatar
Default oewheels stoped selling 17 x 9.5 O_O
HOLY ****, I was going to refer you to oewheelsllc to get some bad *** 17's in the 17 x 9.5 or 17 x 11 sizes but I when on their website and NOTHING.
They are phasing out all there 17's in favor of 18's O_O UNBELIEVABLE.
Old Jul 9, 2013 | 11:54 PM
^ Wow indeed.
Finally found a photo of them on an F-Body:
Old Jul 10, 2013 | 05:56 PM
nascarnate326's Avatar
I dont think they are phasing them out, they have had a problem getting some corvette wheels. Since they only sell Corvette wheels...that means they are just low on supply. Give it time, things will get better.
Old Aug 14, 2013 | 01:47 AM
diaz947's Avatar
I'm looking for a set of 4 17 inch SS wheels for the 1998-2002 Camaro. I'm currently with the stock 16 inch wheels and am convinced that the 17 inch wheels with a shorter sidewall will help increase the handling of my car.
me too>
Old Aug 14, 2013 | 12:31 PM
ybaslo1's Avatar
If you want a set that doesn't look like they set in to far then AFSwheels has them in a 17 x 9.5 with a +38 offset, so they'll set about 3/4" out further then the +56 offset 17 x 9.5 wheels.
Anyone have a pic of these AFS wheels in the +38 offset? One of the reason I do not like OE 17x9.5 wheels (Or any other wheel in there numerically high offsets) is because when you lower the car, the wheels get sunk in.
Also, do the AFS Wheels look identical to the ZR1 DD's? I'm trying to think how an AFS +38 front set and another vendors 17x11 DD ZR1 with a +50 offset would look on a 1.25" lowered car.
I know it would be almost impossible to know, but I thought I'd give it a shot.
Old Jul 13, 2015 | 02:32 PM
Camaro Kim DeHart's Avatar
Thank you to those who replied and explained things in such great detail. I finally "get it" and can order my new wheels accordingly. I've been unsure of doing so since I didn't understand the whole offset thing clearly enough. If I don't get it, I don't do it, period. I had three individuals tell me what to do, and I wouldn't until I fully understood what I was doing. Btw... all three were WRONG. TY again.
Old Jan 17, 2020 | 09:32 PM
Spamfritter's Avatar
Originally Posted by NoHope
I'm sorry but this really doesn't make sense to me. They're the exact same wheels but they stick out further than the regular stock 17 x 9.5 wheels will? I just want wheels in stock size and look, don't care if they're OEM or not.
The wheels look better when they aren't tucked so far into the wheel wells. That's what we are getting at. Wheels that stick out a bit give the car a more aggressive look.
