Fit?
Old Mar 27, 2013 | 06:51 PM
-=Modified=-'s Avatar
Default Fit?
These should fit on the rear of a 2002 Camaro, right?
I think the Camaro center bore is 70.3mm, these are 72.3.
The bolt patter is 5x120. Will the .65mm make a difference? Im sure I could shim them to get the .65 and make them pretty close to hub centric.
Thoughts?
http://www.ebay.com/itm/8MM-BMW-FLAT-WHEEL-SPACER-5X120-CB-72-6-/230951596930?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item35c5c9b382
Old Mar 28, 2013 | 09:22 AM
leadfoot4's Avatar
You could probably get "hub centric rings" in the correct size, to fill the gap.
Old Mar 28, 2013 | 02:11 PM
SSCamaro99_3's Avatar
How are you going to shim anything to remove .65 mm from a circle?
Technically, no, they do not fit.
Old Mar 28, 2013 | 03:14 PM
Magic and patience.
Old Mar 28, 2013 | 03:21 PM
Originally Posted by -=Modified=-
Magic and patience.
Hope you have a lot of that one.
