26" or 28" tire?
Old Jun 28, 2013 | 08:15 AM
alexus6798's Avatar
Default 26" or 28" tire?
My car is full bolt ons and also full weight. I do plan on going with heads,cam and spray but it will be next year before I do. I see a lot of guys running 28" tires. Is it to get more mph or better 60' ? I'm trying to decide between the Et streets and Hossier drag radial but leaning more towards the Hossier. Any help is appreciated. I did search. I'm thinking with my power level that the 26" will be the best but not sure. They will be strictly for the track. I have my stockers for the street.
Old Jun 28, 2013 | 07:37 PM
Blackpanther99's Avatar
Stock rear end gear ratio?
Old Jun 28, 2013 | 07:55 PM
Carter01's Avatar
Unless you want to buy two sets within the next year do yourself a favor and get 28s now. I did the exact same thing and 1 year later when i started spraying the car I had to get 28s. They work much better on spray than a 26 however you can make a 26 work but it won't be as consistent on sketchy tracks as a 28 will be.
Old Jun 29, 2013 | 09:24 AM
alexus6798's Avatar
I'm running 3.73's.
Old Jul 3, 2013 | 07:57 PM
blown97ss's Avatar
im on the same boat. i bought some 26s and now im going for for 28 running out of gear or rpm at the track, hit the rev limiter a couple times in 3rd gear about a 135mph pass.
Old Jul 3, 2013 | 08:44 PM
1320Chicken's Avatar
I did the same thing after getting 4.10s I was running out of gear. For the track the more sidewall you can get the better and I didn't see a drop in mph but left me with enough rpm to spray.
Old Jul 4, 2013 | 10:05 AM
alexus6798's Avatar
I'm thinking with the 3.73's and my power level that the 26's would be okay. I may be wrong though. I think I'm going to just run 26" for now then after I do heads, cam, and nitrous I will try it like that and if need be switch to 28". By the time I upgrade, it will be time for some more tires anyway.
