Wheel & Time Amateur Question!
http://www.oewheelsllc.com/Wheels_3/...2#.UjokRMasiSp
Now, I am very new to doing things with cars so please excuse my lack of knowledge. I am posting this here to get a straight forward answer.
I am wanting to get my tires separately from oewheels for pricing and brand. Now, the thing I have trouble with is knowing what kind of tire will fit the wheel and the car. I don't want to do any sort of fender rolling/trimming, and I don't want it to rub! The sort of tire I was told by OEWheels that would be good would be a 245/40/17, but I don't really know what these numbers mean. Also, the wheels are 17".
Basically, I want to know if these rims will fit that type of tire (or if there is one better). And if it will be a good fit.
Again, any help will be appreciated. I hope I posted this in the right spot, I figure you guys will be the best help!
40 is the aspect ration, meaning that the side wall height is 40% of the width
17 is obviously the rim diameter....
you definitely will not rub. The only time that modification is almost a must is running 315/35/17s and larger or 295/35/18 and larger. that usually includes BFH, possible fender rolling, bump stop cutting.
personally I would try to find a 17x9 or 17x9.5 and run a 275/40/17 a pretty decent selection of tires in that size and you get added traction and handling.
It also depends on your driving style and needs. if its just a daily driver and cruise car you won't need that wide of tires. and you would be fine with 245/40/17s.... just my $0.02
Yeah it's just a daily driving car for me. If you don't mind I have one more question. If I go with a tire like these. Do you think they would be a good choice to go with the wheels?
Nexen N3000 are good tires as well. Also I would run a 245/45/17 instead of 245/40/17, you'll get a taller sidewall and a bit softer more comfortable ride. You should be able to find a N3000s at most tire places except tirerack
Are you looking for a budget tire or a decent tire worth spending some extra money on?
http://www.thetirechoice.com/learnin...tire-size.aspx
I have 18" C5 Corvette Z06 rims on my car. The size of the tires are front: 275 35 18 and rear: 275 45 18. I do not have any problems with there rubbing on the front or the rear. I ended up having to replace the two front tires recently and they were around $220 a piece. Price is one of the major downsides to going with a wider tire.
Since you plan to daily drive the car, it would probably be cost effective to go with a 245 45 17 like DemonicZ said. The cost will be much easier on the wallet because they aren't as wide and they are much more common.
